3vze Accessory Brackets (Power Steering, Alternator)
Old Mar 15, 2020 | 04:16 PM
maxvp01's Avatar
So I did a complete engine tear down, brackets and all to send to the machine shop. I had a pretty difficult time figuring out where each accessory bracket went I had to pause images out of several youtube videos to see how they went. Hope this helps someone who had the same trouble putting back together!
PS Bracket
Make sure the engine hoist hook is behind the bracket that mounts near the exhaust manifold
The second PS bracket uses one of the bolts from the false water pump (fan bracket)
The other bolt goes through the first and second bracket to the head. (Directly above the numbers, I don’t have that bolt going through in the picture)
Different Angles of PS Bracket
Alternator Bracket bolts up right under the neck for the distributor. 3 bolts.
Picture of the front and the adjustment bracket location
Old May 22, 2020 | 07:03 PM
Nicknorie's Avatar
You are a lifesaver! I’ve been looking for pictures like this for 3 days. Finally took the right combo of words for this to pop up. I thought I took good enough pictures, and figured if I didn’t it would be easy to find what I needed. I’m completely surprised this info isn’t even if the FSM’s.
Old Jun 30, 2020 | 11:23 AM
Akira's Avatar
Very cool! Thanks! And also thanks for the inspiration to paint the valve covers something fun!
bajaguy
Sep 11, 2020 06:37 PM
fierohink
Sep 27, 2012 11:01 AM
maicomega1
Dec 22, 2009 01:34 AM
m_dubb
Jul 24, 2009 11:25 AM
Falx
Apr 20, 2009 09:12 PM
