1986 Toyota pickup 4x4 shift pattern & procedure
Old Mar 13, 2020 | 09:15 PM
Christopher Bello's Avatar
Hi my name is Christopher I have just recently acquired a 1986 Toyota 4 by 4 pickup truck with a 22RE motor there are no stickers or decals or shifter knob to indicate or let me know how to shift the vehicle I'm sure there is a procedure orvproper way of engaging the 4 wheel drive do I put it in neutral ,start the engine ,lock the hubs, ? I don't know how to do it can somebody please help me maybe someone has a photo of the decal in the glove box or on the dash or both 😁 bring back LEMONDROP
Old Mar 14, 2020 | 03:52 AM
SomedayJ's Avatar
For decal start here:
https://www.yotatech.com/forums/f120...ovebox-264316/
Old Mar 14, 2020 | 12:46 PM
2ToyGuy's Avatar
Main transmission is a standard H-pattern. 1st is left and up. 2nd is left and down. 3rd is middle and up. 4th is middle and down. 5th is right and up, reverse is right and down, and is spring loaded.
The transfer case shifter is slightly right and below the main shifter.
The transfer case is left and up for 2WD, left and down is 4Hi. 4Neutral is down and middle, and will place both transmission and transfer case in neutral.
4Low is right and up. To shift in and out of 4 Low, always have the truck stopped, or at least below 5 MPH.
It's best to have the main transmission in Neutral before shifting in and out 4WD, either 4HI or 4LOW.
To shift out of 4HI to 2WD, if it seems jammed, stop the vehicle, and back up 3 meters (10 feet) or so. This will "unload" the transfer case, allowing shifting.
You can lock/unlock the hubs before you even start the truck. You can lock/unlock the hubs with the engine running or stopped, it doesn't matter. For obvious reasons, they can't be actuated with the truck moving.
ALWAYS have the vehicle on a surface that will allow the front tires to slide a bit, like sand, gravel, snow, or ice, before making a turn of any kind in 4WD, either HI or LOW.
Get the stickers SomedayJ linked, and memorize them BEFORE you drive the truck. It will save you a lot of heartache, tow bills, and grinning transmission mechanics, when they realize what you've done, and how much they'll make...
Hope this all helps a little...
Pat☺
chrisorbics
Jun 30, 2016 01:24 PM
BrotherAndySLB
Jul 9, 2015 06:18 PM
YotaTruck1986
76
Nov 23, 2004 06:41 PM
YotaTruck1986
Sep 27, 2004 07:03 PM
