Loud knocking at start up, goes away and starts again at higher rpm
Old Jan 12, 2020 | 05:26 AM
22marv's Avatar
My truck is knocking very badly at start up. After I give it a couple revs it’s mostly goes away, but returns at astound 2400 rpm. I played with the distributed and a timing light and it’s gets close to 5 btdc but with the distributer all the way retarded. Is the engine not timed correctly?
Old Jan 12, 2020 | 05:56 AM
SheepishLion89's Avatar
Have you checked if revs/timing adjusts when setting the debug/timing jumper wire? If there is no change, I would see if TPS is properly adjusted.
Old Jan 12, 2020 | 06:04 AM
22marv's Avatar
When I jump the wire I don’t get a drop in revs, but, I do get a check engine light. I will move on to the tps. Would the tps cause the knocking or just the timing issue?
Harold Of The Rocks
Aug 3, 2019 04:31 PM
Chrisz
Mar 18, 2018 04:37 PM
toyocrf
May 28, 2010 08:42 AM
oldblue
Mar 17, 2009 05:47 PM
TurboKH
Dec 22, 2006 03:20 AM
