FS[PacSouthWest]: 99 Limited 4runner|11,000 OBO|Tucson, AZ
(SOLD) 99 Limited 4runner|11,000 OBO|Tucson, AZ
1999 Limited Toyota 4runner 4WD, E-Locker equipped
(SOLD) $11,000 OBO (SOLD)
222K miles
Tucson,Arizona = No Rust! ALWAYS garaged at home and covered parking at work.
Vehicle is very clean, well maintained and in great shape.
Suspension
Sonoran Steel 1.2 Lift Kit Complete
Tires/Wheels
222K miles
Suspension
- Radflo 2.5 Adjustable, 0 inch-3.5 inch, Coil Overs
- Sonoran Steel Fabrication L.L.C. Front Differential Drop Spacers
- WabFab Sway Bar End Links
- 1 inch Roger Brown Body Lift
- Toyota 80 Series Land Cruiser Coils
- Sonoran Steel Fabrication L.L.C. Adjustable Trac/PanHard Bar
- Sonoran Steel Fabrication L.L.C. Extended Bump Stop Adapters with
- Daystar "Competition Style" Bump Stops
- Sonoran Steel Fabrication L.L.C. Rear Sway Bar Adjustment Brackets
- Sonoran Steel Fabrication L.L.C. Braided Stainless Steel Extended Brake Line
- Sonoran Steel Fabrication L.L.C. Brake Line E-Clip
- Sonoran Steel Fabrication L.L.C. Drive Shaft Zerk Plug
- Sonoran Steel Fabrication L.L.C. Parking/Emergency Brake Bracket
- CAMBURG, 1.00 Performance Uniball upper Arms
Tires/Wheels
- BFG ALL-TERRAIN T/A KO2 – 285 70 R17 (33 inch tires)
- BFG MUD-TERRAIN T/A KM2 – 285 70 R 17 (33 inch Spare Tire)
- KMC Enduro Rims
- K&N 57 series Air Intake
- K&N Dry Charger
- Magnaflow Muffler
- Yellow Optima Battery
- 1st Generation 4runner Roll Bar
- LED Interior Lights
- Rear Mod Switch for liftgate window
- Husky floor & cargo Mats
- Alpine head Unit & Speakers
- Alpine 4 channel power Amp,
- V12 Series MRV f305 Amplifier
- XRC Smittybilt Synthetic Winch
- Rear Custom Bumper
- Yakima Load Warrior (Extension Included)
- Yakima Control Towers
- Yakima Spare Tire holder
- Yakima Bracket for 48 inch X-Treme Hi-Lift Jack
- Yakima Extension, & two Bike Racks
- 2 Hella Black Magic Driving Lights
- Integrated Rock Sliders
- Tacoma Whip Modification
- Front D Ring Shackle Mounts * Tow Hook Replacement *
- Smittybilt Receiver Hitch D-Ring Shackle for rear hitch
- 4 pin trailer connector
- 42 inch Low Profile LED Curved Light Bar (I think it’s 42 inch)
- Unique TJM T13 Front Bumper. Steve from Sonoran Steel said that only a few made it to the US.
- *Wired for lights on the roof rack and for lights mounted on the rear of the truck.
- -Mobil 1 synthetic oil and premium gas since 2007
- Spark Plugs, coil packs (OEM) & NGK Wires, 2019
- Valve Cover Gaskets (OEM), 2019
- Front diff bracket DURO Bumps bushings, 2019
- Brake Booster (OEM), 2019
- Cleaned Mass Air Flow, 2019
- Cleaned Throttle Body, 2019
- Grease Drive Shafts, 2019
- Rear brakes replaced (OEM), 2017
- Front brembo rotors, (OEM) pads, 2017
- Starter (OEM), 2016
- Steering rack, (OEM), 2015
- Front/Rear diff. and T case oil change (redline synthetic, 75w90), 2015
- Transmission oil change (redline synthetic MT 90), 2015
- OEM Toyota CV axle, (OEM), 2015
- New OEM Lower Ball Joints 2014
- Fuel filter, 2014
- Alternator replaced, 2013
- Timing Belt, (everything OEM) 168K miles, 2012
- Water pump, Thermostat, Alt belt, PS bel, A/C belt, idle bearing)
- Replaced radiator with a Koyo Radiator & Toyota Red, 2012
- Front Wheel Bearing (Inner,Outer Seal, Snap Ring, Spacer & Skid Control Rotor)
- Rear Wheel Bearing (Type S Oil Seal for Inner Axle & Type K Oil Seal for Outer Shaft, O-ring, Retainer, Skid Control Rotor, Snap Ring)
peepers
May 6, 2006 08:17 PM
