1KZ-TE poor fuel mileage and black smoke
Obviously since I said mileage you can tell I'm from the states. I just bought a 1994 Toyota Hiace imported from Japan with the 1KZ-TE motor. It has 222k km with recent timing belt done.
The problem is that it smokes black intermittently and gets horrible fuel mileage (15 mpg, if I drive it lightly). It has good power most of the time. Every once in awhile it will give great power. And sometimes it'll not have much power at all. It idles pretty smooth and starts easy every time.
I'm a gas mechanic of over 20 years by trade. Not much experience with diesels.
Things I've done:
New Toyota injectors, boost sensor and valve, glow plugs, cold air intake, adjusted the fuel to it's lowest setting (which has made it smoke less, I haven't driven it enough to know the mileage, but it still smokes), checked for clogged screens on the injection pump, adjusted the pump, put a boost gauge (shows 8-10 psi, but the gauge bounces around, so not sure how well it's working), changed all the fluids and filters, new primer pump, I have checked the EGR valve, took it off and cleaned it.
After each thing I did it made it run better. But after I changed the injectors the smoke got worse. The fuel mileage had been the same the whole time.
Please help. I'm trying to leave on a long road trip to Costa Rica soon and want great fuel mileage and better performance and no smoke.
Things I've done:
Welcome to YotaTech!
Unfortunately, there are very few active members that know about the 1KZ-TE here. I really don't know anything about those engines myself.
You might try the Diesel section of the IH8MUD forum: https://forum.ih8mud.com/forums/dies...h-24-volts.24/
They are primarily a Land Cruiser forum but do have much more diesel tech than we do here.
Yancy Calderon
Sep 28, 2019 07:18 AM
mrmojorisinphan
21
Jan 9, 2007 09:31 AM
