1990 Toyota 4Runner SR5 3.0 V6 Auto, Bed liner lower panels all of the way around, swing out tire carrier w/matching aluminum spare, great running and driving rig, drive it home.
I need to sell my 4runner so I can get a truck that can actually tow something. That being said, I'm open to partial trades on top of some cash. I've owned it for a year so far and am currently driving it to and from work, +/- 3 miles daily. Mileage 151,xxx miles. I tore the block down last winter due to freeze plug leaks when I bought it. Engine got all new freeze plugs, new oil pump, new water pump, new thermostat, timing belt and tensioner, new power steering pump and lines, conical air filter, EGR delete, sonic washed injectors and all new seals, new TOYOTA knock sensor and wire, NGK plugs and wires, distro cap and rotor, temp sensor, cold start temp sensor, TPS, new starter, trans filter/fluid/pan seal, new Toyota Ignition, swapped to almost new heads, brand new head bolts, LCE gasket set (non MLS), new exhaust gaskets, new thrush turbo muffler, and likely a bunch of other stuff that I forgot. I have receipts to back up all new parts purchases. Also has roof basket with rear facing lights, 20" front mounted light bar, Bluetooth stereo, and comes with a 4.56 non-ADD front diff w/ IFS lockouts, extra calipers, 16x8" steel round hole rims, extra heater core with blower and good resistor, 4" pro comp suspension lift in great shape with adjustable gas shocks, and whatever else I can find in my shop that will fit it.
Orange crate w/ all lift brackets and hardware, Rims, ECU, heater and blower Shocks and springs
