Toyota transmission fluid question
Toyota switched at the end of the 2003 model year from IV ATF to WS ATF in the new 5speed transmission they are using in the Landcruiser/LX470/GX470 and 4runner. Does anyone know what is the difference in the two fluids? What happens if they are mixed? What is the cost difference? Toyota claims that if you don't tow that you never need to change this new WS ATF fluid (I question that but don't know what this new stuff is). Any information you could give me on this new fluid would be appreciated.
In short, Toyota does not recommend mixing the fluids. As for their suggestion that the fluid doesn't have to be changed for 100K, I wouldn't let my trans go that far. One small problem though, along with the fluid change, Toyota removed the dip stick and tube from the trans. In order to check the fluid level, you have to use a 'sight' plug on the side of the trans, like the standards. You can still drain the trans (partially) by removing the sump pan and then refill it through the 'sight' plug, it just is more difficult. PROGRESS :wtf:
Originally Posted by TechWrench
Do a search on WS ATF, there were several threads on this as I remember.
In short, Toyota does not recommend mixing the fluids. As for their suggestion that the fluid doesn't have to be changed for 100K, I wouldn't let my trans go that far. PROGRESS :wtf:
GreenLion
Jun 7, 2021 10:49 AM
FS[PacNorWest]: T100 auto trans/tcase - Bay area, CA
94whiterunner
Sep 22, 2015 07:25 PM
