Rear heater/cooling pipe/tube?
Old Jan 29, 2018 | 04:25 PM
hayn96762's Avatar
I have a 1995 4Runner 3.0 and have searched everywhere I can online for a definition of this pipe/tube and cannot find the right info except this photo that I borrowed from someone here and with the RED arrow. It's a U shaped pipe with a smaller pipe connecting to a small hose going to the top of the intake manifold. The larger hose connects to the heater valve assembly.
Hopefully someone knows the answer ��? TIA
Aloha ��
Attached Thumbnails Rear heater/cooling pipe/tube?-image.jpeg
Old Jan 30, 2018 | 11:05 PM
wyoming9's Avatar
Red face
You have checked Toyota Parts dealers online ??
Every 4 runner of that age I see the rear heater is long gone .
It seems once the heads come off it is never reconnected
Old Feb 1, 2018 | 12:03 PM
hayn96762's Avatar
Not sure where to look?
I'll check online now. Not sure where tho? Thanks
Old Feb 2, 2018 | 09:21 AM
PreviousOwner's Avatar
I'm seeing that pipe as 87265-89108 or 89109. I usually use the parts diagrams here https://parts.lakelandtoyota.com/pro...erm=8726589109
If I've got the parts right, it looks like they are discontinued and you'll be surfing ebay.
Old Feb 2, 2018 | 10:13 AM
irab88's Avatar
Similarly, look for a "reducing tee" fitting. These typically have 2 measurements: the size of the 2 larger connections, and the size of the single smaller connection. I'm not 100% sure of Toyota's measurements, but you should be able to find some standard sizes that are close enough.
Also, they're dirt-cheap.
Old Feb 4, 2018 | 01:09 PM
wyoming9's Avatar
Red face
You could make one out of copper and solder a nipple on
slacker
May 25, 2014 09:23 AM
oldgold3vze
Jan 21, 2014 10:25 AM
generalcheetos
Mar 6, 2011 09:07 AM
neb11ihtut
Nov 14, 2010 11:05 PM
marty4runner
Aug 24, 2006 04:47 PM
