2nd gen 22re into a 3rd gen pickup truck
Old Jan 17, 2018 | 05:10 PM
Cbrown83's Avatar
I currently have two pickups with 22re motors. One is a 1987 22re with a automatic trans. Its currenly running but needs rebuilt. The body is rough. The other truck is a 90 22re with a manual trans. The motor is currently removed and mostly disassembled. I bought the truck off a guy who only wanted $100 for it so I couldn't resist. The entire truck is in excellent condition. No rust what so ever. So my idea is once I pull the motor out of the 87 and rebuild it, I was going to put it in my 90. My question is what troubles could I run into with the swap. Electrical, ignition, etc. Thanks.
Old Jan 18, 2018 | 12:22 AM
wyoming9's Avatar
Red face
Well if you put the fresh long block into the newer trucks using the engine harness for the newer truck you should be good
All the electronics come from the truck the long block is going in Injectors all the sensors
Old Jan 18, 2018 | 02:33 AM
Cbrown83's Avatar
That would definitely be the easiest way but I'd like to keep the original harness with the 87 for selling purposes.
Old Jan 18, 2018 | 08:43 AM
old87yota's Avatar
You could rebuild the engine (long block) from the 1987 truck and just install the long block into the 1990 Truck, keeping all the electrical components (injectors, sensors, wiring harnesses, ECU, etc.) with the 1990 truck. Both engines in long block form should be the same.
You would then bolt up the intake manifold/plenum, and exhaust manifold from the 1990 truck to the rebuilt 1987 engine.
Then you would install all of the 1990's injectors and sensors to the rebuilt engine.
Basically, the only thing that you would need to swap over from the 1987 truck to the 1990 truck is just the long block engine, keeping everything else in place.
Old Jan 18, 2018 | 10:51 AM
wyoming9's Avatar
I just said the same thing in fewer words I guess The OP did not understand.
Old Jan 18, 2018 | 12:51 PM
old87yota's Avatar
^^ Yes!
I just figured by the OP's response that they were not sure what you meant.
Old Jan 18, 2018 | 04:45 PM
Cbrown83's Avatar
Thanks for the responses guys. Hopefully I can find all the sensors (the wire harness looks like a rat nest). Ill probably just buy new injectors since I'm rebuilding the motor anyway.
Cbrown83
All Other Toyota Swaps
Jan 18, 2018 12:49 PM
Ramiz09
Aug 2, 2016 09:20 AM
youngtoyotatech
Aug 24, 2014 08:14 PM
Elvota
7
May 6, 2008 08:10 PM
funrunner91
Dec 31, 2007 04:26 PM
