1989 22RE Check Engine Light
My 1989 4x4 Pickup with 22re engine, 170K miles, is getting an intermittent check engine light. Seems to come on after driving for maybe 10 minutes uphill. Goes off after a while if driving on level or back downhill. Last year replaced timing chain, mass airflow meter and tps. No problems with performance or anything up until just recently.
I followed the instructions from a thread here and also some similar youtube videos. I have the small diagnostic connector on passenger side of engine. I jumper across the T1 and E1 connector/terminals. When I turn the key to the start/acc position I get a solid check engine light. No blinking to indicate diagnostic code. It seems like a pretty straight forward process but it does not seem to wok for me. Any ideas of what I may be doing wrong with trying to check the diagnostic codes or....? Thanks!
Thanks for your reply! Do I feel stupid. Just by taking the photo I realized, yes I was jumping across the wrong connectors. Couldn't be more clear but I was having a repetitive brain cramp. probably cause I'm turning 60 soon. drain bamage.
So I'm getting code 25 and code 26 next step is to find what those mean. Thnaks again!
OK and Thanks for that. I got a list of what the codes indicate below:
25
AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
--INJECTOR FAULT(S)
-FUEL PRESSURE
--OXYGEN SENSOR
--AIRFLOW METER OR MAP SENSOR
--IGNITION
--ECU
26
AIR/FUEL RATIO RICH INDICATOR
--SAME AS ABOVE
--COLD START INJECTOR
I am searching for info on how to test the O2 sensor. I have found some people stating that it should be replaced after 100K miles regardless. I believe mine is still the original. I'm the only owner and it has 170K miles so maybe I should just order one and put it in? Looks pretty simple to do - two bolts. I'm not a pro mechanic but i'm reasonably handy and have tools, metric sockets etc. Like to do what i can to save $.
25
--INJECTOR FAULT(S)
-FUEL PRESSURE
--OXYGEN SENSOR
--IGNITION
--ECU
26
--SAME AS ABOVE
se7enone, Thank you so much for your helpful replies! I have read about using the Denso brand as preferable and that”s my plan. I have got some confusion regarding wether I have 1 or 2 on the truck. I’m not on CA. I’m in CO and the truck came new from dealer inWY.
I’m going to look in the morning to see. There should be one just under the exhaust manifold inthe engine compartment and maybe another just past the Cat on the exhaust system. If I understand correctly.
I entered my make model erc into a order order on amazon and it returns the same sensor for either location, I think. Sort of confusing.
I’m keen to order asap and desire to get it by Friday. Need to drive from my west slope location, over continental divide to Denver on Sunday.
thanks again!
thanks again!
fayette4x4
May 29, 2013 02:09 PM
SCToy
Jan 30, 2012 05:19 PM
coke
May 22, 2010 06:51 PM
alleycat
May 4, 2010 05:45 PM
goldtaco9
7
Jun 12, 2004 05:28 PM
