Puckup over heated
Puckup over heated
1993 pickup DLX extea cab 3.0 V6 a/t..
Hey guys some advice please: the truck over heated due to leaking radiator, which I fixed, now Im losing coolant into intake, I can tell because my exhaust is white smoke and theres a little milkshake under the oil cap. I pulled the intake and the valley is full of coolant, but i cant tell if its coming from the intake gaskets leaking or the head gaskets. When the head gasket(s) leak, do they usually leak coolant into the valley? Or is it possible its just the two intake gaskets that leaked and the coolant is being pulled into the intake from there? The head gaskets were replaced only a couple years ago and dont look like they are leaking externally. Thank you!
