Sponsored by: CARiD
Stock cluster swap to sr5 cluster
Old Apr 13, 2017 | 05:31 AM
Kadi96915's Avatar
I have a 94 Toyota 3.0 auto 4x4 pickup and I got a hold of a 94 4runner 3.0 auto cluster. I got everything working except the rpm and I'm trying to figure out how to wire it up for the rpm to work. Need to know how to wire it up to get it to work. I know I have to tap I to either the igniter or the ignition coil and from there where do I hook up the wire to cluster. A write up would help, Pics would help too. Thanks
Old Apr 16, 2017 | 01:41 AM
wyoming9's Avatar
Red face
If I understand what your trying to do.
Everything should work after changing the different sending units
Unless you bought the cluster from a 22re vehicle
You should not need to add any wires .
Poor connection or mechanical problem with the tach
Unless you just cut off all the plugs and have a big mess
Old Apr 17, 2017 | 02:57 PM
wyoming9's Avatar
Red face
I see now I misread I thought they were both 4 Runners
In any case the black wire off the igniter should be the tach signal
It should attach to pin #7 of the blue plug from the 4Runner
You understand how to Look at Toyota Plugs like your plugging them into your eyes
The clip is on the top #7 is the 7TH pin from the left
Old Apr 17, 2017 | 03:02 PM
Kadi96915's Avatar
Thanks a lot, I will try it in a bit. I'm currently working on some other things I put off on my truck. Thanks again.
Old Apr 18, 2017 | 09:37 AM
Kadi96915's Avatar
Thanks wyoming9, thanks to you my tach works great. Now I'm working on the oil gauge. I change the sending unit with a gauge sending unit from a 91 Toyota pickup 3.0 4x4 and also changed the oil gauge itself and it's still not working. I'm wondering if it's the sending unit or the oil gauge cluster electrical. Still doing some testing. Thanks again for your help.
