Sponsored by: CARiD
spark just quit
Old Mar 26, 2017 | 07:31 AM
LiL bigfoot's Avatar
spark just quit
Hey, I have a 93 pickup 4x4 with 22re. spark just died going about 40 mph. I found a broken sparkplug wire so i did a tune up. does anyone know if the ignition and coil test is the same on 4 cyl. as it is on a 6 cyl.? help! i've fallen and i can't get up
Old Mar 26, 2017 | 01:04 PM
wyoming9's Avatar
Red face
One broke wire will cause it to miss not quit .
Unless your long over do for a tune up
The tests are the same the specs might be slightly different
You might want to pull the distributor cap and see if the rotor turns while cranking the engine
