Questions about torque converter stall testing
Old Jan 20, 2017 | 01:37 PM
Co_94_PU's Avatar
I'm not a transmission specialist, and what ever I might have learned during my apprenticeship way back in the dark ages I've forgotten..
How does being at, above, and below operating temperature effect the following.
Converter stall testing?
​​​​​​Fluid line pressure?
The only thing that really rings any bells, memory wise, is being way over hot causes the clutch plates to slip more.
Old Jan 21, 2017 | 07:05 AM
Co_94_PU's Avatar
Not even an armchair answer, I find that very surprising! Almost more so not a single "time to swap out for a manual transmission".
Guess I will proceed with fluid checks, color, fill, sniff and spread test.
Old Jan 21, 2017 | 12:00 PM
Mr. No SPAM's Avatar
OK - Here's your armchair guesses:
- Stall testing - Lacking knowledge of stall characteristics of torque converters I'd guess that thicker, cooler oils would cause the converter engage at lower RPM.
- Line pressures - I'd guess that line pressure would decrease as temp increases, due to lowered viscosity.
