1994 Pickup 4x4 v6- 3.73 gears swap?
Hey guys,
Looking to swapping 3.73 gears into my 1994 xtra Cab 4x4. According to research, I have the 4.30 gears (confirmed w/wheel rotation test), 8" rear, 7.5" front. My 5VZ swap and 31" tires leaves me with ridiculously fast acceleration in town, and a screaming engine on the highway. I'm already in 2nd more often than not before even crossing the intersection. I've found a 3.73 third member for my rear end, but haven't been able to find info on if a 3.73 ratio is possible with my front diff. I found one page that indicated that the 3.73 gears from a 7.5" rear may be able to be swapped into my IFS front diff, can anyone confirm this?
I do mostly highway driving, followed by light off-roading (shuttling mountain bikes and climbing equipment) so a more highway friendly ratio is what i desire.
Thanks in advance!
Matt
Thanks in advance!
Matt
This page says that the carrier and gears in 7.5" rear thirds are compatable with an IFS case: I believe them.
http://home.4x4wire.com/erik/diffs/
I see a couple 7.5" Toyota 3.73 rear third members on Ebay that you might be able to take the carrier and gears from, but I don't find any new 3.73 7.5" ring and pinions offered for sale there.
Have you asked a Toyota dealer about new gears???
Manual trans would be 3000rpm 4th and 2500rpm 5th at 65.
That should be perfect for 5VZ and DD
Going from 430 to 373 is a 3 point jump (skipping 411, 390)
I would think you will start burning clutch and binding drivetrain and going
on any strain offroading would break something.
What do you consider a screeming engine on the highway?
Maxx here is running a little higher then normal rpm DD setup, 488 and 32.4" about 2750rpm OD at 65, Nice offroad setup.
3.73 sounds a little short, even for a 3.4 engine. 3.73 is what Toyota uses in the 4th gens with the 4.7L V8, which has a lot more low-end torque than a 3.4.
4.56 is stock with 31's and a 3.0 with a manual transmission. I don't think I'd go below 4.10 with the 3.4 engine.
Thanks for the replies dudes! Well based on responses and some thought I've decided on 4.10s - should give me 2500 rpm at 65 or so. My tires are actually 31x10.5 so really around 29.5" real diameter. I just don't see any need to have the engine in its powerband for cruising - flat highway cruising requires few hp. I'd rather just downshift to pass and/or climb a hill. The 5VZ is comfortable revving high but doesn't necessarily need to - I rarely shift later than 2200 rpm.
And I need to work on this truck haha! If I don't do this it could be something way worse! Like #sas2k17
