'85 Pickup needing new 5-speed manual transmission
Old Nov 29, 2016 | 09:17 AM
Oro's Avatar
Oro
Question '85 Pickup needing new 5-speed manual transmission
Just looking to make sure I don't screw this up. Looking for the correct 5-speed manual transmission to replace the currently worn out one. RWD 22r naturally aspirated gasoline engine. Any help or clues as to how to determine which transmission I need without actually removing the one I've got.
Old Dec 9, 2016 | 10:51 AM
L5wolvesf's Avatar
There should be some sort of ID on the trans or a tag maybe which tells you which model trans you have.
Old Dec 10, 2016 | 09:42 AM
osv's Avatar
osv
either pull off the boots on top of the tunnel, or crawl under the truck and reach your hand up around the top of the trans.
https://www.marlincrawler.com/transm...built-complete
see the photos there... also look on the marlin forum.
there is often a number stamped on the bottom of the trans case, but it didn't add up to anything, when i replaced my trans.
