I've tried searching for this part, and for an answer. Mine is cracked, I need to replace it.
I thought it was the air intake tube/hose, but according to the internet it's either:
a. on the other side of the airbox
b. just the rubber end on the left
intake crossover pipe/tube would be my guess. i don't think i've ever seen a new one for sale, its usually the rubber ends that would fail. there's a few on ebay if you're looking for a stock one, otherwise you can get a piece of metal intake pipe and achieve the same thing. there's also the option to do a battery/intake swap.
how bad is the crack? try some PC-7 epoxy. scuff up the plastic with sandpaper and/or a razor blade to make texture for epoxy to grab.
