86 22rte body swap
Old May 26, 2016 | 08:15 AM
jeepmonkey's Avatar
86 22rte body swap
Morning I found a rollover 86 pickup with the 22 rte engine. Everything looks good so I removed the body and found a 48 Jeep pickup cab to drop on , now trying to sort out what wires I need to run . It will run by tapping the cold start injector manually .So far all I have hooked to the ecu E01,E02,no10,no20,IGt,E1,IGf,Vcc,VTA,Ne,BATT,+B1,+ B and connected NSW and STA to + 12 v .....Hope there is enough info here , thanks in advance
Old May 19, 2018 | 09:21 AM
Racersk's Avatar
The cold start is wires off the starter signal and a coolant temp switch in the intake keeps it on as temp requires. both the coolant switch and timer ar on the front of the intake manifold by the thermostat.
Old post- but was never answered.
