Sponsored by: CARiD
zuk mod ?'s for 1984 bandit (2wd p/u)
Old Apr 19, 2016 | 09:33 PM
dickyditch's Avatar
hi,
i'm planning on doing a zuk mod on my 1984 bandit (like a chinook, 2wd pickup with a pop-up mini motorhome). the back is getting kind of saggy and i just want to bring it up to level.
i'm clueless about coil springs. wondering if anyone can recommend which springs to use, what length/weight?
consider that i'm always driving under load and the weight on my rear axle is about 3200 lbs.
also, i lost about 3/4 of an inch cause i had to switch to smaller rims to get a 6-ply tire.
because its spring under axle, i'm going to have my welder buddies make me custom mounts and weld them directly onto the axle/frame, so spring diameter shouldn't be an issue.
let me know if any measurements would be helpful, my friend is borrowing the bandit but should be back by the weekend and i can get more specifics and/or post pics then.
thanks!
dicky
Old Apr 23, 2016 | 03:22 PM
dickyditch's Avatar
Hi, just nudging this thread again, looking for any input! thanks!
Old Apr 23, 2016 | 06:22 PM
Robert m's Avatar
If it was me, I would rather put a set of helper bags on the axle with a tank and small compressor than a set of coil springs. That way you can adjust the height and ride on the fly. You could also set it up to have accessible on board air for tires, tools, air beds, or anything else while camping or out in the sticks.
Old Apr 24, 2016 | 06:26 PM
ZUK's Avatar
ZUK
dd-
Can't give any recommendations unless you have the distance between the 2 shock saucers. Are you thinking about 2.5" OD coils(black diamond brand) or 5.5" OD?
Old Apr 25, 2016 | 05:44 AM
ZUK's Avatar
ZUK
Also, a couple of snapshots of the region where the coils are planned to be located would be helpful.
kawazx636
Feb 22, 2024 04:21 AM
Tkeehr11
Feb 21, 2016 05:57 AM
FinallyOffRoad
Feb 19, 2016 06:29 AM
Tyler Zemlicka
Feb 4, 2016 11:18 PM
jbaldo
Jan 28, 2016 08:45 AM
