I recently bought a '98 4runner with 311,000 miles on it. It runs great but has some electrical issues.
The rear wiper, window, and defroster don't work (altho the defroster light turns on). I've read up on the issue and have tried jiggling the wiper. I also confirmed the window works by connecting it directly to the battery. My key doesn't turn the rear hatch lock so I can't tell if the window operations works by key.
I have almost no experience with electronics. The most I've done is solder a headphone cable back to together.
I tore off the panel to see what I could find and I see there is an empty blue box labeled Control Unit. The box is empty, I'm assuming this is not good? Or is it's only function to hold some of the wires? None of them seem to fit snugly in there.
Here is a picture of the box and the nearby wires
As you can see, there is nothing in the blue box and none of the stray plugs seem like they'd fit in there.
I found this picture on the forum, but I can't really make out what's up.
Sorry if this is a stupid question, I'm just learning! Thanks for the help!
On closer inspection, it looks like the white plug should plug into the blue box, but the blue box is missing the plug? Since that's missing and my key doesn't turn in the tailgate lock, perhaps this isn't the original hatch?
It turns out the blue box houses the rear ECU. The PO of my car must of tipped out the ECU but left the blue plastic housing for it. Bought a new ECU, plugged the white plug into it, and everything worked!
