What causes a surging idle at 2rpm?
Old Feb 16, 2016 | 06:53 AM
d-wood's Avatar
When I hold the gas at 2rpm it surges. It does it after its cranked for about a minute or so. It's a 93 22re. I thought it might have been from a vacuum line that the po plugged but I have another post about why the po did that and some said there's is also plugged. Any thoughts?
Old Feb 16, 2016 | 09:46 AM
kcaudill's Avatar
engine cold or warm when surging? There is a ton of topics about surging idle. Need more info. Mine did the same once at operating temps. Found it was a clogged idle air control valve.
Old Feb 16, 2016 | 05:39 PM
d-wood's Avatar
Right on. Well mine does it when it's about a min ute or two of starting it up. Thanks.
Old Feb 16, 2016 | 10:26 PM
Terrys87's Avatar
Burping the coolant system will cut down on the surging. Raise the front end up high and let it idle with the radiator cap off for 4 or 5 cycles of the thermostat to get the air out of the system.
kawazx636
Feb 22, 2024 04:21 AM
Dakotaant
Feb 13, 2016 06:51 AM
Rapidrob
Feb 13, 2016 06:40 AM
jbaums
Feb 9, 2016 11:45 PM
studeb
Jan 28, 2016 08:08 PM
