How to remove this rivet?
Old Jan 18, 2016 | 12:45 PM
Rapidrob's Avatar
How do you remove this center pin rivet from the door panel? The vinyl has pulled away from the leading edge and I want to glue it back down?
I know how to remove the window crank and the door latch. Are there any other tricks to pull the panel off?
Thanks.
Old Jan 18, 2016 | 02:04 PM
donomite49's Avatar
It looks like a push pin. Push the pin in the center and the whole thing will pull out.
I use a Phillips screwdriver to push with.
After its out you push the pin towards the front, not all the way, so you can reset once it's back in place.
Old Jan 18, 2016 | 02:33 PM
highonpottery's Avatar
X2 you push in the center "pin" of this connector about 1/8-1/4" deep, it clicks IIRC -- and then you can pull out the whole part. They're quite a genius design I think.
Old Jan 18, 2016 | 03:44 PM
Rapidrob's Avatar
Thanks guy's.
Rapidrob
Jan 18, 2016 12:34 PM
abalagtas
Jan 17, 2016 11:50 AM
Redrezzer
Jan 12, 2016 09:21 AM
wyoming9
Jan 3, 2016 11:43 PM
gilby4runner
Dec 28, 2015 04:48 PM
