Advice Needed Broken Bell Housing 99 4Runner
Bought a 4Runnner knew it had a broken flex plate. Pulled transmission out and found the bell housing cracked in half. With this much damage what else should I replace or scrape it? 224k miles on it, body is very good.
Concerned that when I put it back together I will find more major issues.
Thanks
Thanks
At some point in it's life it has been wrecked. I can see the frame was repaired and what I am fairly certain is a dent in the oil pan that matches the cross member perfectly, it could have been made that way, but I doubt it. This is my first 4Runner so I am a true novice. I would say the accident happened a long time ago because clear coat on the hood has already started to peal.
btu44
Oct 7, 2016 08:03 AM
charlie_fong
Dec 28, 2015 05:31 PM
