Pre 84 Trucks 1st gen pickups
Need a new line for the slave clutch cylinder
Old Jan 17, 2016 | 10:57 AM
jkj2000's Avatar
I purchased a new slave clutch cylinder and screwed up while installing it, cross-threading the line connection. No way I can clean that up.
Is there any place I can get a replacement for this piece? I've attached a pic. I don't know anything about flaring brake lines so would need something either plug and play or a workaround from the auto parts store, if possible. Any help gratefully taken...thanks!
Attached Thumbnails Need a new line for the slave clutch cylinder-img_0086.jpg
Old Jan 17, 2016 | 01:13 PM
wyoming9's Avatar
Red face
Buy the correct size line both in length and in the nuts at most auto parts stores
Then bend it to fit as needed being careful not to kink it.
Maybe time you learn how to flare things ??
Old Jan 17, 2016 | 01:29 PM
jkj2000's Avatar
Thank you, I went to the parts store and the helpful clerk found a pre-flared line with the correct fittings, at the size I needed. After some careful bending I got it installed.
Regarding on learning how to flare, I think you're right! (The clerk also showed me a tool they rent for doing it.)
Alchain
Feb 9, 2016 09:39 PM
natnat5
Nov 10, 2015 03:48 AM
Shouldbhuntin
Nov 6, 2015 05:01 AM
vinman33
Nov 4, 2015 11:53 PM
shisha1999
Oct 21, 2015 02:14 PM
