FS[PacNorWest]: 1984 4runner smog equipment
I have about 99% of all the California model 22R 4runner smog equipment.
located marysville ca, 95961 (I have tons of pictures and videos of me removing everything for reference for buyer) I will probably put it all on a CD or something.
-ac pump, bracket and hardware
air pump bracket and hardware (belt only has 700 miles on it and is oem toyota) hoses are there but ends are cracked and old
-tons of misc vaccuum switches, solenoids what not
-air injection comes with the LCEPERFORMANCE adapter to use on a header.
-bsv valve(s) that big block bolted to intake manifold that runs to the air injection tube or whatever its called
bunch of hard line metal tubes used for smog
-egr with new gaskets
everything related to smog minus emissions computer is/will be available
also
oem, rebuilt asian carb of my 84 4runner. I worked on tuning and it was a PITA but I passed california smog and drove it for about 7 months before deciding to do weber and clean everything out.
$300-smog equipment plus shipping (shipping will be pricey the pumps alone are very heavy
$300 carb, plus 4 studs, gaskets and oem air cleaner
keep in mind its all 30+years old but I still passed California smog in bay area not the cleanest, but def not barely.
pm me if interested, not looking for trades or parts please don't waste my time and I wont waste your. don't like my price make me a (reasonable offer) but the air pump alone is over $400 from dealer, i never found one at pick n pull and crapyzone/orileys tards never able to order one.
the smog equipment will 99% be there, everything I can remove will be available.
also
200 for all smog equipment
250 for carb
Shipping the smog stuff would be kind of expensive the brackets and pumps are heavy.
Plus all the ac stuff the ac works great with new ac fluid too. No leaks and for 30 years old blew pretty cold
250 for carb
no ones needs smog equipment for a 84 4runner or pickup? its all the same for california models and I passed smog with it twice.
also have a good, working oem asian carb rebuilt, hot tanked in the aluminum safe cleaner and everything gone through, was tuned to my set up so will need mior changes for yours depending on exhaust, cam, compression etc.
choppe777
May 16, 2016 08:00 AM
noosh
Aug 21, 2015 03:49 AM
