High idle with the A/C off
Old Sep 4, 2015 | 04:36 AM
Ktm526's Avatar
I got my A/C working yesterday by putting a belt on the compressor and recharging the system. With the A/C on it it idles a Little high but sounds right to compensate for the load of the A/C. With the A/C off however the motor is revving I'm guessing to around 1000-1500 RPM's. Any ideas on what to check to get it to idle normal with the A/C off? My truck is completely stock and has not been modified. Has a little over 27000 miles on a 22r.
Old Sep 14, 2015 | 10:04 AM
user 82300's Avatar
the following link has a picture of the oem Asian carb with the adjustment screws labeled.
disclaimer: I would not adjust the air/fuel mix screw without a manual it seems to be more trouble then its worth without having the instructions with you.
https://www.yotatech.com/forums/f120...a-smog-264872/
Old Oct 7, 2015 | 05:14 AM
Ktm526's Avatar
It was the linkage. But thank you!
tomczaksdiesel
Jul 26, 2015 10:35 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
jackiebrownia
Jul 20, 2015 09:02 AM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
