Non-A/C P/S pump bracket?
I have a completely non-functioning A/C unit in my '95 4Runner 3.0. I am also replacing the P/S pump at the moment and it looks like the bracket that comes off the A/C condenser also supports the P/S pump. If I remove the A/C system completely (yes, I could just leave it but it clears up the bay if removed), is there a special bracket that non-A/C trucks used to tie the P/S bracket to the lower block, or is it unnecessary? I never use A/C because I have windows and a sunroof in the works.
I have the 91 w/o AC straight from the factory
I can't see it clearing up anything $30 worth, whole area remains crowded with P/S hoses and ignition wiring. There's always a hacksaw and grinder with new paint as a solution. My project was replacing a leaky steering gear. And this is the 22RE so might not be helpful, good luck
jon.r
Jul 11, 2015 03:34 PM
