E6 Connector from a 2001 Tacoma
Hi there, I have been browsing around the forum for awhile and finally am at a bit of a road block where I need some help.
I have a 2001 Donor Engine/Engine Harness/Body Harness/ECU combination that I bought from the wreckers. I don't plan on having cruise control or Air Conditioning.
My question is regarding the following plug: E6, more specifically, Pin 13.
Pin 13 has a green/black striped wire and follows along to the 4x4 module.
The issue is that in all of the literature that I have read (TIS/Forums/etc) this should be the ACT/ AC Amplifier wire, and should be the color "L-B"
Now I am at odds with this, because the entire E6 plug only has the 1 wire and I don't know how this happened. Should I reposition this wire to the #18 pin for the 4x4 module?
Any help is much appreciated!
Thanks!
Thanks!
FS[FourCorners]: First Gen Tacoma/4Runner Manual Hub Spindles
G-off
Dec 29, 2015 12:44 PM
zz_denis
Sep 6, 2015 03:43 PM
LJR
Sep 5, 2015 06:02 AM
