New here
Old Dec 10, 2014 | 04:41 PM
yota21's Avatar
New here
Hi everyone I just got a 84 pickup 4x4 4cyl, and I was wondering how to tell what gear ratio it gas because there's no tags anywhere?!
Thanks
Old Dec 10, 2014 | 07:12 PM
muddpigg's Avatar
1) Open dif: lift one tire and turn it one revolution. Count revolutions on drive shaft. Helps if you mark it.
Locked/welded dif: lift both tires.
2)Pull dif count teeth on ring gear and pinion.
Old Dec 11, 2014 | 02:20 AM
Terrys87's Avatar
If the tage is still on the firewall under the hood, just behind the motor, it will have a gear code on it. Here are the codess.
