List of all light bulb types?
Old Dec 8, 2014 | 07:22 PM
nevermore1701's Avatar
After being out of the 4Runner game for a few years, I picked up a '90 SR5 this morning. Got a wild hair to swap all the bulbs except the headlights for LEDs. Is there a comprehensive list of what bulbs go where that I can use while shopping for the replacements? I did a few quick searches on my phone, but didn't see anything.
Thanks!
Old Dec 8, 2014 | 07:27 PM
JasonYota's Avatar
Interested in this as well. Looking for exterior lights or interior lights or both?
I may have a small list of inside light numbers.
Old Dec 8, 2014 | 07:38 PM
Everything but the headlights, interior and exterior. Just think it would be a fun, cool looking, relatively easy and cheap mod.
Old Dec 8, 2014 | 07:42 PM
muddpigg's Avatar
Where are you guys planning on sourcing lights? Have you heard of fasttech.com prices are much cheaper than other sources I've seen.A guy at work told me about them, he has ordered a mod for his e-cigarette from them and was very pleased.
I plan on swapping out bulbs also. Found a bulb for dome light at walmart $6 bucks kinda let down. The 2 little LEDs that make up the bulb just don't seem to put out much light. That site has a couple other options that fit into internal light fixtures I might try later after holidays.
Old Dec 8, 2014 | 07:45 PM
I was looking at superbrightleds.com, but haven't started seriously shopping as I'm not sure what exactly I need.
Old Dec 8, 2014 | 08:15 PM
Nervo19's Avatar
superbrightleds has a search tool that tells you what size bulbs to get for exterior brake, turn, licinse and back up lights. Get the bulb color that corresponds with the lens color: red for brake etc. (Duh, I guess) I spent last night searching threads and can't figure out exactly how many of which bulbs to order for the SR5 dash. I want to do clear in my 89. I got a bunch of 6 or 8 LED torpedo bulbs off eBay for about $6 and changed them in the '89 and the 2000 4Runners. The same size fit all the interior ceiling lights but don't fit the 2000 map lights. I think the dash needs 194 and 74 bulbs but I'm not sure how many. Can anyone comment on how many to get? Manual, 22RE,SR5 swap.
Old Dec 8, 2014 | 09:01 PM
KBAM's Avatar
Would like to know as well. Just picked up a 91 SR5 3.0 and it has a few lights out... Would like to convert over to some nice LED's.
Old Dec 8, 2014 | 09:05 PM
Superbrightleds has good info on the exterior stuff, interior not so much. Also, is a resistor needed for the blinkers?
Old Dec 8, 2014 | 09:11 PM
KBAM's Avatar
There's one way to find out! Great website... Looking over it now.
Old Dec 10, 2014 | 09:19 AM
UZI - SUICIDE's Avatar
I just did mine..
I repalced the Taillights with
http://www.ebay.com/itm/191338519129?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITIt had a regular 1156 reverse light bulb so I bought an 1156 LED from Wal-Mart to replace it
They work very well reverse lites are nice and bright and they look good too...
I wanted Daytime Running Lights so I replaced the 2 wire Bumper Lights with
http://www.ebay.com/itm/160911768879?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITand
http://www.ebay.com/itm/331207817337?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITwith
http://www.ebay.com/itm/371160302493?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITSo they come on with the engine and turn off when the headlights come on..
I replaced the headlights with
http://www.ebay.com/itm/181516663859?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITand they looked tuff, and everybody liked them but in a couple days the pass side had melted the plug which I replaced and a few days later they started doing some weird and I ended taking them out and smashing them so I didnt put them back in eventually..
That pretty much covers it except I havent done the side lights but they are T-10s
Bumper Lights 1156 - Tail/Brake Lights 1157 - Reverse Lites 1156 - Corner Lights - T-10
No, I dont work for e-bay...
Old Dec 10, 2014 | 09:29 AM
You can get around using Resisters by getting a electronic blinker relay for LEDs.. just make sure if you do not have all LEDs that the relay you get can handle both types of bulbs..
Otherwise ya gotta use the resistors which get very hot so mount them to metal.
You can also modify the stock blinker relay by thinning out the metal thing inside it with a dremmel to raise the resistance if you are super cheap and have a dremmel..
If you dont do any of these things the stock blinker relay will read the lower voltage draw from the LEDs as a burnt out bulb and you will have hyperflash and if you use switchbacks they wont work properly..
Old Dec 11, 2014 | 06:12 PM
I ordered a flasher module to combat the low resistance of the LEDs. Guy said it worked for his '94 Yota pickup, so hopefully it'll be good on my '90 4Runner.
Dumb question, but where is it, in the fuse box? I haven't got out and looked yet.
https://www.superbrightleds.com/more...c-flasher/782/
Old Dec 12, 2014 | 10:08 AM
yep...
Old Dec 12, 2014 | 10:18 AM
4Runner
Toyota 4Runner
First generation (1984–1989)
(1984, 1985, 1986, 1987, 1988, 1989)
High & low beam headlight H6054
Parking light 194
Front turn signal 1073
Rear turn signal 1073
Tail light 1157
Stop light 1157
License plate 194
Back up light 1073
Front sidemarker 194
Second generation (1989–1995)
(1990, 1991)
Parking light 168
Front turn signal 1156
Rear turn signal 1156
Tail light 1157
Stop light 1157
License plate 89
Back up light 1156
Front sidemarker 168
Instrument-general 194
(1992)
High & low beam headlight 9004
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1156
Step/Courtesy light DE3175
(1993, 1994, 1995)
Parking light 168
Tail light 1157
Stop light 1157
High mount stop light 921
License plate 168
Back up light 921
Glove box 74
Map light DE3022
Step/Courtesy light DE3021
Step/Courtesy light DE3022
Trunk/Cargo area DE3175
Old Dec 12, 2014 | 11:00 AM
JasonYota's Avatar
^^ any idea why some for the 92's are different? Figured they would be the same 92-95
Old Dec 12, 2014 | 01:00 PM
muddpigg's Avatar
4Runner
Toyota 4Runner
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1073
(1990, 1991)
Parking light 168
Tail light 1157
Stop light 1157
License plate 89
Back up light 1156
(1992)
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1156
(1993, 1994, 1995)
Parking light 168
Tail light 1157
Stop light 1157
License plate 168
Back up light 921
Glove box 74
Map light DE3022
Cool reference.
Old Dec 12, 2014 | 07:44 PM
4Runner
Toyota 4Runner
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1073
(1990, 1991)
Parking light 168
Tail light 1157
Stop light 1157
License plate 89
Back up light 1156
(1992)
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1156
(1993, 1994, 1995)
Parking light 168
Tail light 1157
Stop light 1157
License plate 168
Back up light 921
Glove box 74
Map light DE3022
I got everything but the interior figured out, but that's a fantastic list!
Old Dec 13, 2014 | 10:49 PM
Yeah, My instrument cluster lights (late 89 DLX 4x4) there is 2 possible types of bulbs used and the only way to find out for sure which i have is to scatter the dash out and look...
Old Dec 14, 2014 | 08:15 AM
highonpottery's Avatar
also maybe try pfanleds -- pfran was/is a forum member at ih8mud who started doing group buys on LEDs direct sourced from China. Now he's got a business and does other vehicles than landcruisers now. I've got some from him for my cruiser and damn they're almost too bright.
Old Dec 14, 2014 | 11:12 AM
I'll check him out, thanks!
