Sponsored by: CARiD
Fuse Block Wiring harness '94 4Ruunner
Old Jun 22, 2014 | 04:44 PM
crimewave666's Avatar
I recently pulled the lead that runs from the positive terminal on my battery to replace the previous owners crappy piece off speaker wire he used. The main 8 guage wire runs up to s metal square with two holes for the wires that run into the rest of the fuse block. One side has two red and blue wires that come off of it and the other side has a single red and blue wire. I am a knuckle head and can't remember which side gets which wire. Does anybody know? Does it even matter?
Old Jun 22, 2014 | 11:46 PM
wyoming9's Avatar
Red face
One must learn to pay attention before pulling things apart.
The 2 wires go to the 60 amp ABS fusible link pin 5 the single wire goes to 30amp fusible link AM2 pin 1
Old Jun 23, 2014 | 07:33 AM
Thanks Wyoming 9. Yeah I took a pic with my cel phone but I must not have saved it.
I was trying to remember which side the wires bolt to one the little 1" square plate at the end of lead coming off the battery (not where the red and blue wires go). There are two holes in the plate that the wires bolt two one side bolts up the 2 red and blue, the other side gets a single red and blue. When you are looking head on at the plate, I can't remember which side (left and right) gets which wire.
Does this make more sense?
Old Jun 23, 2014 | 10:25 AM
wyoming9's Avatar
Red face
It is a copper plate it does not matter as long as the wires end up in the correct location
As long as the wires are long enough to get where they need to go .
If the first try is to short then they go the other way not like you have 20 different positions .
Old Jun 23, 2014 | 09:06 PM
Copy that! I'm tearing back into it tomorrow. Thanks for the help, if it blows up Ill be back on this thread for more advice/direction. Thanks for responding.
MO transplant
Apr 23, 2023 11:58 AM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 17, 2015 10:13 AM
88yodabasket
Jul 13, 2015 01:32 PM
colinmil
Jul 6, 2015 04:03 PM
