my busted bucket; need help with a botched valve adjustment
Old Apr 16, 2014 | 03:55 PM
excel8951's Avatar
attempted valve adjustment today.
all was going well and I had finally figured out how to get the shims out.˟
UNTIL...
I spun the crank to check the other 8 valves without replacing 2 of the shims I removed. As result I nicked one of the buckets and put 2 small divets in either end of the associated cam lobe.˟
The bucket does still seem to hold a shim OK.˟
I found the 2 chunks of material that came out of the damaged bucket so I know they are not floating around in the head.
My question is can I just let this go or do I need to start pulling cams to replace the damaged bucket. I have NO IDEA how to do that so I am hoping I can just let it go.
How can i go about pulling the cam if i need to? Its only the exhaust cam that would need to come out.
AGAIN, The bucket does still seem to hold a shim OK so maybe I dont need to worry about it?˟
check out the attached pics.
I included a pic of an undamaged bucket for comparison
thanks
Attached Thumbnails my busted bucket; need help with a botched valve adjustment-2014-04-16-14.18.08.jpg   my busted bucket; need help with a botched valve adjustment-2014-04-16-13.42.23.jpg   my busted bucket; need help with a botched valve adjustment-2014-04-16-12.52.33.jpg
Old Apr 16, 2014 | 03:57 PM
excel8951's Avatar
The dinged up cam lobe
Attached Thumbnails my busted bucket; need help with a botched valve adjustment-2014-04-16-12.54.57.jpg
Old Apr 19, 2014 | 04:37 AM
skypilot's Avatar
You can carefully dress it with a fine stone and be sure to catch the debris with vaseline. Otherwise it should be fine since the arm rides in the middle and doesn't use the whole surface.
Blamalam
Mar 12, 2022 07:34 AM
DukeOfHazard
Aug 16, 2015 01:48 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
razorman8669
Jul 12, 2015 12:13 PM
