coolant leak under the throttle body-1987 Toyota 4runner
i have 1987 toyota 4runner and it has develop really bad coolant leak under throttle body. so today i took out the throttle body and still its really hard to reach. i noticed its really short hose and its connected to the block at one of the ends.
what i need to know
1.) what is the easiest way to replace this hose?
2.) what is name of the hose or a part# to buy it?
really appreciated any kind of help or advise in this matter. thanks.
https://www.yotatech.com/forums/imag...ies/wedgie.gif
https://www.yotatech.com/forums/imag...s/yotarock.png
what i need to know
https://www.yotatech.com/forums/imag...ies/wedgie.gifhttps://www.yotatech.com/forums/imag...s/yotarock.png
Something does not look quite right.
I need to look when it gets light out .
Yours could be different because of your AC
just get yourself a piece of hose and replace .
i doubt there is going to be a name or a hose you can ask for.
It looks like that fitting screws into the intake manifold or is it just the angle of the picture??
This could turn into a very interesting job.(pita).
I doubt the hose can be replaced without moving something.
To replace the hose the manifold might need to be loosened then the gaskets need to be replaced .
I need to look in the day light.
interesting thing the hose the OP is talking about is not on that diagram.
Nor does it look to go to the AAV.
Not having to really pull it apart I just looked.
If they feel it is by all means go for it.
Spicer
Apr 7, 2026 07:17 PM
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
JaredL
Jun 16, 2015 04:47 PM
Looks like this very well may be an adventure.
