Wiring Harness repair
I was swapping out a transmission in my 99 4runner 3.4 auto and though i had all the connectors unplugged from the wiring harness and forgot one and ripped the wires out the back of the plug. the plastic part is good but i can't get the wires back into it. i believe its the plug for the trans temp sensor. its on the passenger side and right beside the large connector on that side. does anyone know where i can get another plug that has the wires coming out it and i can just splice it in? i looked for spare wiring harness from the local yards but can't find any
Those plugs can be a pain to play with.
I know when I wired my diff lock switch light I had t o pull a locking piece out of the connector to be able to slide the correct wires with their connectors in.
Here is a pic of what I am talking about ( from here, BTW : http://sonoransteel.com/phong/retrof...ic_locker.html )
and you can see the white piece I had to pull out that holds the terminal ends in place.
With any luck, yours is a similar situation.
Good Luck, and Hope this Helps !!
Britt
Britt
Here comes more info than you ever dreamed of about Toyota Wire Harness Repair--418 effing pages!!!:
http://wilbo666.pbworks.com/w/file/f...RM1022E%29.pdf
Toyota, as far as I know, does not sell just the pigtails. They do sell the connector housings and any needed pin/wire combos separately. This saves you a lot of change if you just need the housing.
The last five digits of the housing part number are usually molded into the piece. Add those digits to 90980- and you get the full part number for the housing. Then order the wires/pins you need, if any, to complete the repair and away you go. The wire/pin pieces for each connector are listed in the manual linked above.
The manual also has the 'tricks' needed to insert and remove the wire/pin combos from each type of connector housing. This info may be all you need.
What makes it real fun is being in the strange positions needed to repair this.
I am not sure but is the harness group long enough to pull it back into the engine compartment making it so much easier.
To repin the connector.
88yodabasket
Jul 13, 2015 01:32 PM
