General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
PLZ HELP! 84 4Runner, nothing works but the headlights...
Old Dec 11, 2013 | 07:11 AM
oldyotaholic's Avatar
As it says, I have an 84 4Runner SR5. It has a 22re swapped, based off the ecu numbers looks like it came from either from a 91 or 92 pickup. I don't think that has anything to do with my problem, but I wanted to make that clear up front.
On lunch break yesterday I drove to get food, parked the truck and turned it off with the key like normal. 15 minutes later I go to get back in the truck and when I turn the key I don't get power to anything but the headlights. No radio, heater controls, dash lights, turn signals, or anything. Headlights turn on, but no tail lights or brake lights. Flashers dont work either, they should work without the key shouldnt they?
Things Ive done so far to diagnose:
-Bypass starter signal, engine cranks over for 10+ seconds. Battery and starter are both good.
-Replaced ignition switch, still nothing
-Checked all fuses and relays that can be visually checked, nothing seems to be blown.
-Checked all wires to ignition switch with multimeter, no voltage at any terminal. Should be power coming into the switch somewhere, right?
So my truck is stuck on the side of the road, hoping to get it fixed soon so I dont have to pay for a tow. Plus we just got snow on the ground, not a good time for my only 4wd vehicle to go out
Any help would be greatly appreciated, thanks in advance.
Tyler
Old Dec 11, 2013 | 08:43 AM
andlours's Avatar
Do a double check on those fuses. Mine did the same thing about a year ago. The problem on mine was an 80 amp fusible link in the under the hood had been blown. That sound like your problem to me. It's the black one.
Old Dec 11, 2013 | 09:35 AM
Thats the next one on my list, I just found out about it. Didnt get a chance to check it last night. After you found your fusible link to be blown and replaced it, did you have any further trouble with it? Was there a short somewhere in the truck that caused that fusible link to blow?
Old Dec 11, 2013 | 12:32 PM
wyoming9's Avatar
Red face
Most times a short is what causes it to happen
That or a loose connection some place
Sounds like a open fusible link
Old Oct 19, 2014 | 08:55 AM
mj37kennedy's Avatar
no power too radio or signals
my 03 4runner just did same sort of thing but it will start with a boost but no power to radio no signals no fan windows dont work .All dummy lights on...Any ideas
Old Oct 19, 2014 | 09:21 AM
wyoming9's Avatar
Red face
any electrical problems before this started??
I would say look at the battery terminals !!
What sort of voltage are you reading at the battery??
One must start at the power source and go from there.
Old Oct 19, 2014 | 09:56 AM
No there was not 4 ways work back hatch works but no signal no radio...Could it be alernator
Scotttekoch
23
Nov 1, 2021 12:41 PM
Cesarl74
Apr 23, 2016 06:07 PM
gog1968
Jun 22, 2015 05:55 AM
