4WD Wont Stay Engaged!!! 92 Pickup
I have a 92 Toyota Pickup 3.0 4wd with a manual transmission and the problem that i have is that when pull the lever down to engage into four wheel drive it won't stay engaged and the lever pops back out into the 2wd position. The previous owner had to have a locking ring system to the floor inside to the cab that held the lever in 4wd just to drive it that way. What happens is that i can put it in 4 hi and drive normal but once i push in the clutch to shift the lever pops out of 4hi and back into 2wd. Anyone have any ideas or something that can help me. Thank you
Couple things to check:
1. Verify that the body lift allows the shifter to engage 4 hi, without hitting the floor.
2. Check the shifter seat, might need replacing.
3. Check to make sure the detent ball and spring are in good shape. There is an allen screw near the top of the transfer case. Behind this screw should be a spring and a ball. Just make sure you don't lose either.
Road Bull
Oct 10, 2015 04:55 PM
cyclist231
Jul 7, 2015 12:56 PM
