1994 4runner making a grinding type noise in front end
Just started making a grinding type noise in the front of the truck sometimes it does it and other times it does not...When I engage the 4 wheel drive it stops.Also what type of fluid put into the 4 wheel drive?
Thanks in advance!
Thanks in advance!
More information about your truck would be helpful
Manual or auto hubs?
Have you checked the fluid levels in your front diff?
Have you checked the fluid levels in your transfer case?
If the answer is no to the fluid questions now would be a great time to replace them
Have you pulled your front hubs apart to grease and inspect them?
The more we know about the truck the better we can get you help
Good luck
Good luck
truckmike26
Jul 24, 2024 10:24 AM
