sucking fuel now 94 3.0 runner
Old Aug 14, 2013 | 04:24 PM
skinny's Avatar
ok so after my blowen head gasket repair which included
recon jnjectors from flamethrower
plugs
wires
some temp sensors
the truck seems to run better than before
but I think I lost my mileage
i did mess with the tps because I had a prevous issue and I replaced the tps and set it on truck so I bench set it but then i messed with it again because I thought it was a problem turned out to be bad ground
last check on tps the main setting was in
but I did not check all the spaecs
looking for any ideas
oh cel is not on and I have not run codes (will there be without cel on )
Old Aug 14, 2013 | 04:35 PM
Gamefreakgc's Avatar
Check all the specs for your TPS. If misaligned then it might cause your MPG drop.
The Flamethrowers don't guarantee better mileage. You might have had clogged injectors or poor spark leading to poor combustion and by replacing it all, improved performance and now it's drawing as much fuel as it should have been in the first place.
Why do I know this? I was running on 5 cylinders when I got the truck I have now. Once fixed, my MPG's dropped from 15.5 to 14.0. Course, I've got it back up to 18 now but that's a different story.
Old Aug 14, 2013 | 04:43 PM
skinny's Avatar
there is a chance it was on 5 before
i will have to wait till week end to check rest of tps
Old Aug 14, 2013 | 08:11 PM
Punchy's Avatar
O2 sensor is damaged, O2 sensors don't like antifreeze.
Old Aug 15, 2013 | 05:12 AM
Team420's Avatar
Yep, fouled o2 sensors = poor mpg's.
Set that tps correctly as well.
Alaskan91
Sep 21, 2015 04:39 AM
OffroadRalph
Jul 2, 2015 07:28 PM
rwh2toyota
13
Jun 27, 2015 05:39 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
nyk08trx
Jun 18, 2015 09:01 PM
