Pre 84 Trucks 1st gen pickups
1982 front driveline cv joint bad
Old Apr 27, 2013 | 02:48 PM
82yoter's Avatar
Hey everyone I got a 82 short bed & the cv joint on the front drive line is bad. I checked it & it has a lot of play in it. It also makes a lot of clacking noise when I put it in 4wd & lock the hubs. Anyways I've never replaced one so I am wanting to no ware to get one & how much they cost. Also is their a tilt steering column I can put in it.
Thanks Erik
Old Apr 27, 2013 | 03:40 PM
catfish21's Avatar
That's a solid axle cv joint ??
Old Apr 27, 2013 | 03:47 PM
slacker's Avatar
I would think it's the front drvshaft !!
not sure where you USA guys can get a new shaft from , I would think some guys like pats drive line , if you have em in the US .. i'm sure some one else will set you straight on that .. and i believe your correct when you say " & it has a lot of play in it. It also makes a lot of clacking noise " as to REPLACE it .
you can rebuild them , but not the splines , and the "play" is most likely the splines .
you can also put any tilt unit from 81-83 truck , just make sure you get the colum cover as well
Old Apr 27, 2013 | 05:32 PM
kawazx636's Avatar
What are we talking about here? Birfields, driveshafts or steering columns? Your post is vague about where this "play" actually is
Old Apr 28, 2013 | 08:23 AM
82yoter's Avatar
I was talking about the cv joint on the front drive line wright ware it bolts to the transfer case. The play in it is I grab it & push on it it moves up & down more than I think it should. As far as the steering column I was just wondering if their was any out their for my truck. Hope this explains it better.
Old Apr 28, 2013 | 11:11 AM
kawazx636's Avatar
That would be a Universal joint, not a CV joint. Easy to replace with a press. As for the steering shaft, look for one in a junk yard
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
ptb12
Jul 5, 2015 01:49 PM
