Timing Chain Bandaid?
Hello All,
First, I'd like to say this forum is incredibly informative and it's members are not only helpful, but most seem genuinely concerned with your problems which is awesome. Anyways, I just picked up an 88 p/u with a 22re and I'm starting to hear a tick. I'm 100% sure it's the timing chain guides. I would love to just get in there and change it out, but I work 6 days a week and this truck is my dd. I'm expecting to be off for at least a week in mid march, so I'd like to tackle the timing chain at that point, but I'm looking for a temp fix to last me till then. Using the search function, I came across 1 or 2 people saying that you could use heavier/thicker oil to hopefully prevent the chain from cutting through the cover, but no one verified if this was a valid temporary remedy? I have some rotella 15w-40 ready to go in, if this is legitimate.
Any help would appreciated.
If it just started and your planning to replace in about a month. I would think you'll be ok it takes awhile for the chain to get into the water passage. I knew a guy who went six months with no guides and it didn't make it into the water passage. He had gouged the cover but we reused it that was 6 years ago and no problems to date.
You're certain it's not an exhaust leak? The manifold-to-downpipe donut gaskets are pretty common for blowing out. Or any hardware may come loose. Check around a bit, don't just assume its internal engine noise. I would hate (laugh) if you did a timing chain and your tick was still there after all that work...
If anything I would notice the guides being off as soon as I pop the valve cover off right?
See, I get paranoid. I don't really know if it just started or I was overwhelmed with joy from getting my first toyota and didn't notice it lol. Hopefully the bandaid will last the month.
Thanks for the responses everyone
just take the valve cover off and shine a light down there to SEE if it is indeed your guides. then if it is get some steel backed ones from lce or engnblder. the guide that usually breaks is the drivers side.
Thanks for all the help so far guys
EDIT
I'm starting to think it may be this valve lash I'm hearing about, because the ticking is constant rather than just being at idle
I would still check that exhaust system really well, especially since the PO did exhaust just prior to purchase. He could very easily have used inferior products/parts causing an exhaust leak somewhere.
And valves being out of adjustment is very common.
Sounds like valves to me. A header makes the valve train noise louder. You would think your engine is coming apart at startup if it were your timing chain. Its loud. These engines are normally noisy straight from the factory.
You need to pull the valve cover off and look at the guides. While you are in there, go ahead and adjust your valves. It will take you all of 45 minutes the first time you try it. Lots of people adjust down to .007 for intake and .011 for exhaust to quiet them down. Like I said though, if you are running a header, it automatically makes them louder.
Also, when you start a new thread, always state your year and engine in your first post so people don't have to guess or ask. You can always just list that info in your signature line as well, but guys who just get on the forum using their phones can't see the sig, or your location.
Sep 4, 2015 09:27 AM
that stuff is like honey so it worked great!
