Which brand Fuel Filter
Old Nov 26, 2012 | 09:09 AM
TidalVA's Avatar
Looking to pick up a fuel filter from Advance Auto today. Does anyone have any experience, good or bad, with any of the non-OEM fuel filters?
Old Nov 26, 2012 | 03:16 PM
MudHippy's Avatar
Well, at 115K miles it probably doesn't even need replaced. My 3VZ-E had a little over 200K miles before I finally replaced the original OEM fuel filter. Don't know whether it did me any good to change it or not. Didn't make any noticeable difference. However, that wasn't why I replaced it. At the time I was just looking to spend money replacing things that were relatively cheap, and might need replaced anyway. So, for ~$20 I went and picked up a NAPA Gold fuel filter. Not sure how much better or worse than OEM it might be. But it seems to have been working just fine for the last 30K mles or so.
As a matter of fact I'm about to go pick up another NAPA Gold fuel filter for my other rig(98 Monte Carlo). Since it's been about 60K since it's been changed...and it ain't got no huge-Toyota style-last forever-type fuel filter. It's got one that's like half the size(if that) of the one for a 3VZ-E or 5VZ-FE, even though it's for a 3.1L V6.
BTW, as far as I can tell, the 3VZ-E and 5VZ-FE(as well as the 1UZ-FE and 2JZ-G(T)E) use the exact same fuel filter element. The reason for the different OEM part numbers for each appears to be due to the fact that the frame mounting bracket(which isn't the same for pre/post-96 4Runners or Lexus vehicles) is included with the OEM fuel filter assembly. For example, the part # for a NAPA Gold fuel filter(canister/element only) for a 3VZ-E or 5VZ-FE(or 1UZ-FE or 2JZ-G(T)E) is FIL 3319(and that doesn't include the frame mounting bracket).
NAPA Gold Fuel Filter # FIL 3319 interchange list
This website also says they're the same: http://www.nitomainc.com/npsp3.php?masterno=23300-65010
One more thing that should clarify my line of reasoning on the matter...
Old Nov 26, 2012 | 03:54 PM
Vang530's Avatar
I chose Wix, nothing really fancy...my Toyota OEM one wasn't even that dirty. ('85 22re w/150k miles).
Old Nov 27, 2012 | 01:34 PM
MudHippy's Avatar
NAPA Gold air filters, oil filters, and fuel filters are all made by WIX.
NAPA Gold fuel filter part # FIL 3319 = WIX fuel filter part # 33319
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
pyramid
Jul 30, 2015 10:05 AM
ddg71
Jul 24, 2015 01:24 PM
Fundy Rider
Jul 16, 2015 01:35 AM
