Would lint build tool but need your help
Ok I want to build the tool for pulling axle bearing. I work at a place with a laser steel cutter so I can cut required flanges
The issue my runner that has bad bearing is my daily driver so can't tear apart to get measure ments
This is where you guys come in
I need the hole spacing and sizes of the end of the axle housing or the flange the bearing sits in
I also need to know the diameter of the bearing seat area of the axle or inside bearing measurement
I will post all measurements along with info on tool build
I have the stuff available to build the tool if I can get the info
I have read lots of posts and if I wanted it seems I could just beat it against the ground to get it off
So back to my request if any one has the time and the pieces to measure could you send the measurements
RobotMoose
Feb 22, 2020 07:44 AM
