Tapped in rear main seal too far.....
Old Oct 1, 2012 | 08:22 PM
SkiRig's Avatar
While installing the new rear main seal in my 92 4runner v6 I accidently tapped it in too far(about 1/16" too far). Do I need to pull it out and buy a new one and try again?
Old Oct 2, 2012 | 07:02 AM
MudHippy's Avatar
Yes, and no.
No depends on whether or not the oil pan is already off, or needs to come off(for whatever other reason). Because there's a way to fix what you've done without have to remove the oil seal and buy a new one. But you'd have to lower the oil pan(and baffle plate) so you could remove the oil seal retainer. Once the oil seal retainer was off, then you could push the seal out until it was flush with the outer edge of the retainer. Then install the retainer and oil seal as an assembly.
If removing the oil seal retainer isn't feasible, then yes. You should probably just bite the bullet, go get a new seal, and try again.
Old Oct 2, 2012 | 09:04 AM
SkiRig's Avatar
Yea, I would probably feel better if I tried again with another seal.
Old Oct 3, 2012 | 08:58 AM
SkiRig's Avatar
I can sleep better now, installed a new rear rear main seal last night, went in nicely.
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
razorman8669
Jul 12, 2015 12:13 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
toyoda8488
Jul 5, 2015 10:18 PM
