engine sputters after warm up
Old Jun 26, 2012 | 12:17 PM
Brian Bunch's Avatar
I got a 2000 4runner 3.4 ,runs good when cold but after driving and warms up it starts sputtering out of the exaust,the same when it is warm and starting it sputters,it did this about 2 months ago and I replaced the plugs and wires and it went away and now is back,any idea's on the problem will help
Old Aug 30, 2024 | 03:13 AM
luishernandez2000's Avatar
Same problem
Im having the same problem how did you fix it?
Old Sep 8, 2024 | 06:24 AM
Malcolm99's Avatar
injector failed, they are usually intermittent, but fail after a heat soaking. swap coil and wires to make sure, then order all 3 injectors for the side that is failing, usually #4 misfire for some reason on a 99+
mike250
Feb 16, 2020 03:07 PM
gpb9900
Nov 4, 2008 08:17 PM
skm
Oct 21, 2006 09:29 PM
