rims that dont rub???
I have a 1992 toyota 4x4 x-cab that i wanted to put just plain black cheap rims on. My tire guy told me he only carried one rim that didn't hit the calipers for it. He also said most guys just grind it off ,but that they would not do that. So my question is wich brand rims are you guys putting on similiar trucks that wont rub. Thanks in advance
Just about any rim, 15" diameter or larger with 4.25-3.75 backspacing should fit with no rubbing on the caliper.
I wouldn't suggest any less than 3.75" backspacing unless you're prepared to do constant servicing on your wheel bearings.
Wabbitt) I did try searching .Found nothing on caliper rubbing or why. Thanks for your input
highonpottery ) yea i thought about just painting my stock ones black,but one of the rear ones have to be replaced cause its bent.So i thought I might as well buy new. Oh and the tires are 30x10-15 Thankyou for your help
So i dont know. Looks like i will just wait till i find a cheap stock one and paint up all 4 black
1uzRunner
63
Nov 10, 2018 03:58 PM
Cycles
Sep 29, 2015 06:37 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
