95 4Runner 6" susepnsion
well....I decided not to get the 96 cuz i ran into a way clean 95 with a brand new engine, and it looksl like maybe more stuff is available for the 95. Im looking for a 6" suspension lift whose got the best one ? I want to clear 35's for sure and will probly have to regear. Thanx in adavance for the info !
Best 6" suspension lift would be 4" lift springs and 2" drop hangers. Only problem is those things do not just bolt on.
There are a number of ways to get 35's on a 95 runner, some of which are even being discussed in other threads right now.
Total Chaos Fabrication and EIB both make 6" long travel front suspension setups, which are bolt on. I think you're basically on your own for the rear suspension in terms of getting 6" of lift, I think you'd be looking at maybe a chevy leaf spring swap or custom coils.
4" + 3" body would work, but i tend to avoid bodys. i have a 4" procomp and 33s. it sounds like your 2 best options are the total chaos front + many rear options, or the most badass option, a SAS (solid axle swap), this would articulate way better than any ifs kit and the 6" would be pretty easy to get, this would probably be the more costly route. if you want to do the chaos front +rear, you can get a 4" leaf spring and shackle it, which is probably what id do
What all is needed for the SAS. I think im leaning more that way. The SAS vs. TotalChaos the SAS would have more clearance correct ? When doing the SAS what front end is used ? old toy front or like dana44 or what ? then what leaves steering components etc. Is there any write ups. I pretty sure i could do it myself i just need to figure out whats needed. THanX in advace.
Is there any in here with 95 SAS ?
Peace
Peace
Flying91
45
Apr 11, 2024 04:39 PM
BeMiceElf
Oct 10, 2015 09:40 PM
