Hey guys I need help my with truck it wont start
Old Apr 17, 2012 | 10:47 PM
85CamoYota's Avatar
Exclamation Hey guys I need help my with truck it wont start
I just replaced my Head on it. It is a 22re and all the wires are connected and it is not getting fuel. So my question is, is there a fuel bleed port on the EFI? Also when should I have power to my fuel pump?
Old Apr 18, 2012 | 07:35 AM
egesledder's Avatar
There is no fuel bleed port since your fuel recirculates back to the tank. To see if you have fuel pressure, you can crack the cold start injector loose while you're cranking, just a little bit though or fuel will spray everywhere. If fuel comes out, you have fuel pressure. Your fuel pump should have power when you start cranking the engine. If you don't have power to your fuel pump, start checking over all of the wiring connections you would have touched.
Old Apr 18, 2012 | 09:48 AM
85CamoYota's Avatar
Thank you for the help
Aleeex_u
Jun 5, 2016 06:52 PM
Bamripzit
Jul 19, 2015 01:17 PM
marcusSRG
Jun 27, 2015 07:13 AM
mick l
Jun 21, 2015 09:27 AM
nyk08trx
Jun 18, 2015 09:01 PM
