3.0 issues
Old Feb 18, 2012 | 12:50 PM
scott90's Avatar
3.0 issues
90 3vze.when it's cold it takes a while to start then it spits and sputters and the fires up but sometimes runs down a cylinder for a couple seconds,other times it will start up fine,one of the worst problems I have I's that at high rpms it will pop and cut out,low on power too. It's not the afm or igniter or coil, but I still pull a code 14. It rains a lot here do i can't test things very often so if there's something that sounds obvious that I can replace let me know I need help.
Old Feb 18, 2012 | 01:23 PM
topdog63's Avatar
Have you checked the timing?
Old Mar 22, 2012 | 12:47 AM
scott90's Avatar
No I have not but it runs fine at lower Rpm's and warmed up
Old Mar 22, 2012 | 01:42 AM
ogjohnboy's Avatar
check your cold start valve. might be either unplugged or bad.
Old Mar 22, 2012 | 03:13 AM
scott90's Avatar
So the cold start timing switch is located directly to the left of the coolant temp sensor correct,it's pretty small compared to the coolant temp sensor with a single wire on it also correct?...if so I looked at it the other day and it looks all gunked up and corroded...also would a vacuum leak cause a loss in power and intermittent cut outs at high rpm? Also forgot to add that this 3.0 is out of a 94 pickup.
tobylab
Jan 18, 2016 07:06 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
tobylab
Jul 12, 2015 12:53 PM
Coreyr384
Jul 10, 2015 11:13 AM
