Old Apr 20, 2016, 09:09 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
how do I change power steering fluid?
Old Jan 20, 2012 | 05:28 AM
YodaPala's Avatar
What do you do, suck out fluid from resivour and unscrew that big plug from the rack and pinion unit and drain it from there?
Old Jan 20, 2012 | 06:10 AM
skypilot's Avatar
Just undo both lines off the steering box. Not completely mind you; just enough for them to leak into a drip pan. have some coffee or beer while it drains. When it stops just tighten the fittings and re-fill with fresh. Clean up up with engine degreaser.
Old Jan 20, 2012 | 07:30 AM
enapa's Avatar
How often should this be done?
Old Jan 20, 2012 | 07:58 AM
cubuff4runner's Avatar
He doesn't have a steering box. It has been a long time since I have seen the rack & pinion setup. I would jack the front tires off the ground, find the most accessible and lowest steering line and remove it, the big plug may work I'm sure somebody will chime in. Once it has drained I would turn the wheels back and forth a few times. Hook it back up - fill the reservoir, turn the wheels back and forth again a few times. Turn the engine on for a minute or so and let it sit for a while and top off the reservoir again.
Old Jan 20, 2012 | 08:13 AM
snobdds's Avatar
It's more of a let the pump move the old fluid into a tub while pouring in new fluid type of job.
Here is a write up for a landcruiser, but the same principles apply
http://forum.ih8mud.com/80-series-te...ing-fluid.html
Old Jan 20, 2012 | 09:20 AM
scuba's Avatar
Search next time, please.
https://www.yotatech.com/forums/f2/3...ng-post-81347/
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
cars-guy
Jul 11, 2015 07:51 PM
jon.r
Jul 11, 2015 03:34 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
