22re Runs rough sometimes
Hello, I have a question for everybody out there. I have a 94 toyota pickup 22re and it idles rough. It does it hot or cold when I am just sitting there idling. It wont die but it just seems like it idles to low. It seems to only do it sometimes. Other days it seems to do fine. What should I check for? Thanks Brad
Check the air intake plumbing for cracks. Any induced air after the AFM will cause idle issues. Also check for vacuum leaks. Since it seems to be an intermittent problem, check all hoses and electrical connections. Could also be a dirty injector that's leaking.
Check the basics first.
I replaced the cap and rotor, and plugs, but not the wires yet. I should replace the vac lines as they are looking old and dry. Is there a kit for the vacuum lines or do you just buy vac. line by the foot? I do not think it anything to major. Also the belts squeel. Should I pull them off and then start it, or just pull them off and check all the pulleys? Thanks
